Author Topic: What did you do to your bike today ?  (Read 3557680 times)
« Reply #19575 on: April 07, 2015, 07:41:42 PM »
Changed the bars for a Renthal super bike set. Should save my back somewhat. Got lucky and all the custom short cables made for the flat bars work OK.  Ordered a Yosh copy 4-1 for it.  The police are doing db checks, and it wouldn't have passed with the 4-4 mega's.
You.l probably have more issues with the 4:1 then. They tend to be much louder  :(
the Yosh might be loud...but an sohc4 with 4 open megas is really fargin LOUD, ear splitting loud, sonic reducer loud, women and children running and crying loud, grown men gnashing their teeth loud...
Offline Tintop
« Reply #19576 on: April 07, 2015, 08:02:08 PM »
and that's at idle ;D ;D ;D ;D ;D
At least now the Harleys will get stopped for the db check, not me. ;)
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #19577 on: April 08, 2015, 07:41:20 AM »
Re-re-routed the fuel lines.
Airbox mod.
Also built myself a new fuse panel for ATC fuses. No pics, though... all tucked away now!
Got some final touchups done on my headers. All black again now! Going to properly bake on the paint this time.
--Evan
1975 CB750K "Rhonda"
Offline DaveBarbier
« Reply #19578 on: April 08, 2015, 08:15:11 AM »
Just waiting on a shorter clutch cable from Motion Pro...stuck in Cali right now. Hope it makes it's way to the east coast soon! Also I've been looking into getting an English wheel to try my hand at making a new seat with a hump. Should be fun!
1978 Honda CB550K
Offline evanphi
  • Apparently I'm an
« Reply #19579 on: April 08, 2015, 03:57:06 PM »
Something came in the mail today! Thanks Rafi! (aka edwardmorris)
Shop night on Friday!
--Evan
« Reply #19580 on: April 09, 2015, 03:28:50 AM »
Started to sort wiring in headlight bucket for good.  Now that's a sixpack job if I ever saw one.
Offline Tintop
« Reply #19581 on: April 09, 2015, 08:09:52 PM »
Do yourself a future favour and buy some of those little stick-on numbers for all the connections.  If you ever have to go back in makes life simple. ;)
77 CB550 Cafe build
Offline InAquaVeritas
« Reply #19582 on: April 10, 2015, 09:44:55 AM »
Picked up most of my engine today.
Got it ported, lapped, milled and cleaned. It got a new matte black finish, top to bottom.
Can't wait to start building this thing back up! Any pitfalls to look out for?
Verzonden vanaf mijn iPhone met behulp van Tapatalk
Surf bum trying his hand at wrenching!
Past "bikes" ;)
1981 Honda MT 50cc - Torn apart, put back together and got run down on..
1994 Derby Senda R 50cc - Fell apart
2001 Derby Senda R 50cc - 13/45 changed to 15/70, hit 90 kph in under 150 meters! Undriveable fun!
1987 Suzuki GN250 - Sold
1977 Honda CB750 F1 - F2 engine, '05 ZX6R front end and wheels, '04 ZX6R shortened swing arm converted to twin shock. http://forums.sohc4.net/index.php?topic=133411.0
1987 Honda XR600 Supermoto conversion. CR250 forks and triple. SM wheels, discs front and back. Rebuilt engine. Loudest exhaust in the world: Leovinci X3
Offline evanphi
  • Apparently I'm an
« Reply #19583 on: April 10, 2015, 09:59:23 AM »
If you're going to use the 8 cylinder dowels between the jugs and head, make sure they're not any taller than the surface of the jugs. If you had the surface honed, they may stick out and make difficulty sealing the head gasket.
--Evan
« Reply #19584 on: April 10, 2015, 07:14:02 PM »
Holy crap the head is pretty !! ^^   Was just going to say I have rode my everyday rider I worked on a little this winter and throw up some pics for you voyeurs. New tapered  steering bearings, fork seals, fork boots, correct front turn signal stems, tach seal,, 12 pack,couple bottles of hooch, cleaned front brake, set tappets,more wood in the woodstove, another drink,  new plugs, pull carbs and clean, more booze while spraying K&N filter. Probably more I forgot. Still needs waxing. Was thinking about bolting up some stock pipes but they interfere with my nylon bags not pictured. Bike runs good on to the next. Hit my crusty Z1 and the 750 so far this spring on the road and am shooting for a quickie spin on my unfamiliar GS 1000 next sittin' by the front door. Only got like 4 miles on it so far. Gonna be a busy summer and some things have to got to go also, like some bikes and get my truck out of storage to move thing around!!  Hello Spring.
« Last Edit: April 10, 2015, 07:23:12 PM by ekpent »
Offline goldarrow
  • one day, i'll be an
« Reply #19585 on: April 10, 2015, 07:20:19 PM »
Erik, with all those beautiful bikes and you covered them up???
CB550 K0
« Reply #19586 on: April 10, 2015, 07:27:58 PM »
  Those are a few but I have enough blankets to maybe open a shelter someday,most bikes get one. Keep them covered and cozy and clean for the next owner someday and less polishing for me.  My old German Shorthair here at the house likes a binky on it also at night.   :D
« Last Edit: April 10, 2015, 07:29:57 PM by ekpent »
« Reply #19587 on: April 10, 2015, 07:35:48 PM »
It keeps em warm in that Winter Wonderland!
Offline goldarrow
« Reply #19588 on: April 10, 2015, 07:55:48 PM »
Guess so! We don't cover up down here in lalaland, we just ride them!
CB550 K0
« Reply #19589 on: April 11, 2015, 07:03:15 AM »
you mean germen BIGFOOD....they can svim 4 km ,,if ve left it behind at shore hunting..and sailed to the small ilands...fantastic dogs ,,both as Family and hunting..Sharp but still frendly..
Markcb750
« Reply #19590 on: April 12, 2015, 05:41:13 PM »
Today I figured out why the LED lamps in my rear turn signals cross talk!
Honda saved a few yen by using on unusual circuit on the dash board turn signal indicator lamp.  Just attached the RH & LH hot connections to each side of the indicator bulb, knowing the lamp would ground thru the filament of the non flashing turn signal lamp.   :) :o
Remove the bulb and the turn signals with LED's and a  electronic relay work just fine.
Ha, now I just need to set up a separate circuit to flash the bulb; Air Force B.E.T.  paying dividends.
Ordered a new dashboard harness fro Z1 enterprises, and some LED indicator lamps from evilbay.
Might as well go in whole hog!
Oh and I filed my taxes... ::) :(
Offline DaveBarbier
« Reply #19591 on: April 12, 2015, 05:55:40 PM »
Crap...something I need to do. Doesn't take long, but I always postpone it.
1978 Honda CB550K
Offline joeyvans
  • Definitely not a
  • God's Country, Earth
« Reply #19592 on: April 12, 2015, 06:18:08 PM »
Did "The Works" tank treatment in the morning.  Filled her to the neck and road about 70 miles in the afternoon.  This 'new to me' 550 runs really nice.  But, man if I run her at 4K revs and over, I feel like the swiss cheese HM323's are going to rattle apart.  Absolutely love the look of the original 4-4's, but I might have to install my 4-1 sooner than planned.  I hear these 550's love to be revved, but I haven't even hit 5K on the tach yet.  Am I missing out?  Also, I checked mileage and I ran 36 with most of the miles at 65 (3,500 rpm in 5th) on the highway.  How normal is this?  (550K2)
Anyways, here are a couple before and after picks of "The Works."
1976 CB550 K2
Non-SOHC4 - 1974 CB450 K7
Non-SOHC4 - 1996 VFR750F
"No matter how much you shake and dance... the last three drops go in your pants."
Offline MoMo
  • Ride like you're invisible
« Reply #19593 on: April 12, 2015, 07:33:58 PM »
Good job cleaning the tank.   You should get 45 to 50 mpg and the bike should rev way higher than 5k.  Check the air filter box for obstructions or a dirty filter...Larry
Offline joeyvans
  • Definitely not a
« Reply #19594 on: April 12, 2015, 07:42:37 PM »
Larry, it will rev over 5k, but I haven't had it that high on the road due to the rusted out exhaust. Next, I plan on checking timing, tappets, points, air etc to see if I can squeeze another 10 mpg out of her. I appreciate the input! Nice to know I should be getting better mileage. It was seriously windy too, so that probably played a role. - Kyle
1976 CB550 K2
« Reply #19595 on: April 13, 2015, 12:56:08 AM »
Tank look fine! You used vinegar to remove the rust?
Offline joeyvans
  • Definitely not a
« Reply #19596 on: April 13, 2015, 05:08:24 AM »
No, I wanted to use something that would work a little quicker, so I used "the works" toilet bowl cleaner method. This method is posted everywhere, but these were my steps:
1) removed petcock, poured old gas out, & dried up tank with compressed air.
2) plugged holes with rubber stoppers from HD
3) poured in 3 bottles of "the works"
4)  shook tank every 5 minutes resting it on different sides for about a half hour.
5) got cleaner out and quickly neutralized with baking soda/water mix
6) ran warm water through the tank pouring out both petcock & filler holes for about 5 minutes
7) poured water out as quickly as possible then poured a can of denatured alcohol in, swished around for a few minutes to soak up moisture.
8 ) dumped out alcohol and blasted tank with compressed air.
9) once completely dry, I fogged with wd40, then sloshed some gas around. Dumped out gas and poured in another bit of gas and sloshed around... Dumped. (This step was probably unnecessary)
10) installed petcock, filled to the neck with 91 octane & a shot of seafoam and went riding.
Whole process only took about an hour. No pinholes... everybody is happy!
Kyle
1976 CB550 K2
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #19597 on: April 13, 2015, 12:02:18 PM »
After more than a year in storage, got her into the new shop, cleaned her up and woke up the new neighbours!
Offline mrbreeze
  • Not your average
« Reply #19598 on: April 13, 2015, 07:37:07 PM »
Where's your chrome framed scooter at Derek? That's the one I like.
MEMBER # 257
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #19599 on: April 14, 2015, 10:26:40 AM »
It's next. :-)
