Author Topic: Removing a cb750 engine  (Read 17033 times)
Offline guitarking135
« on: April 03, 2014, 11:07:49 AM »
Ok let me first get this out of the way. I'm new here. This is my first time messing with an older honda like this and yes I'm building a bobber out of it. I know that is some what taboo amongst the CB world but they bike was cheap and looked like crap but ran great.
So I'm at the point of trying to get the engine out of the bike. I'm also at that point of throwing things and profanity. Is there some trick to getting this thing out of here? I'm not finding a whole lot of help online other than put it on it's side and remove exhaust studs.
 If this helps any the frame is supposedly a 79 although the engine is sohc and the wheels are wire spoke. Also the frame doesn't appear to have the mounts that a 79 should have. All that being said I'm trying to avoid cutting the frame to get it out but dangit there's got to be an easier way that what I'm doing.
Any help? Right now it's stripped down to main frame and engine
Re: Removing a cb750 engine
« Reply #1 on: April 03, 2014, 11:18:17 AM »
lighten the frame of extra parts as much as possible. wheels, forks, seat, batt, swingarm, etc....
drain the oil and remove the oil filter housing and oil pan.
remove the breather cover on top of the valve cover.
Loosen all engine mount bolts
lean the bike over onto its right side, onto carpet, cardboard, blankets, grass...etc.
take out all the mount bolts from here, and lift the frame up and off.
takes a little twisting and wiggling, but it can be done by one person.
Install a 754 frame kit  ;)
« Last Edit: April 03, 2014, 11:21:12 AM by flybox1 »
Offline madScientist
« Reply #2 on: April 03, 2014, 11:20:13 AM »
Hang in there bud you'll get it.
There are a couple ways to do it. However one of the easiest ways i've seen is to remove the engine mount bolts, roll the bike to the yard, put it on it's side, and lift the frame off the engine.
Others have done it with an engine lift and some cajoling. There's also the option of cutting the two parallel bars on the frame under the backbone and welding in gussets to make that section removable. That will also allow you to service the head components in the bike later without having to remove the engine. Search "gordon frame kit"
You CAN do great things...with enough beer.
78 cb750f
http://forums.sohc4.net/index.php?topic=113293.0
70 CL350 Street Tracker / Cafe
http://forums.sohc4.net/index.php?topic=125641.0
83 KZ1100ltd
76 GL1000
71 Kaw H2 (to be built)
77 cb750A (sold)
74 cb125s (sold)
Offline saltcitycafe
« Reply #3 on: April 03, 2014, 11:22:49 AM »
+1 really laying it on its side is the way to do it. Yeah it takes some wiggling and swearing but only for a few minutes
« Reply #4 on: April 03, 2014, 11:30:23 AM »
Don't know why everybody has to flop them on there side all the time. My son and and I can have an engine on the bench in less than an hour taking time for a sip here and there without dealing with all the extra hassle. Really not that hard if you have a helper.
  In your case if the engine and frame are not a model match maybe things would be more interesting.
« Reply #5 on: April 03, 2014, 12:03:26 PM »
yeah yeah yeah....helps when you have like 50 bike to practice on  ::) ;D
Offline lucky
« Reply #6 on: April 03, 2014, 12:20:03 PM »
Do not forget to remove the vent cover (three screws) on top of the engine first AND the oil filter!!  1978 models and earlier.
Offline mcswny
« Reply #7 on: April 03, 2014, 12:37:15 PM »
Just go slowly and pay attention to when and where you need lift/pull/ and rotate. Because at times you'll have to do all three. It's a small clearance but once you find the sweet spot, its easy (thats what she said, HEY-OH)
1972 CB750 K2
1997 XR600r (street legal)
1975 XL250
198 XR80
Online PeWe
« Reply #8 on: April 03, 2014, 12:44:10 PM »
I planned to use the pole method next time. Bike on wheels (3 dollys for wheels and side stand), move the bike out from the engine
http://forums.sohc4.net/index.php?topic=118994.msg1492658#msg1492658
But I did the frame mod instead when my frame and engine are just repainted, job needed was lifting the head.
« Last Edit: April 03, 2014, 12:53:04 PM by PeWe »
Offline katman
« Reply #9 on: April 03, 2014, 02:03:33 PM »
I have removed 2 on my 75 and 77 during there rebuilds. Carbs, oil filter and top breather off. 2 people right out the side.
« Reply #10 on: April 03, 2014, 08:12:35 PM »
just got one ready to pull tonight, it took me 2 and a half hours to get it to the point where I need a son, ha ha...plus it was an f3 so it had some extra complications
Offline goldarrow
  • one day, i'll be an
« Reply #11 on: April 03, 2014, 08:29:09 PM »
I do it one man show.  Check my 750 build thread for some ideas
CB550 K0
« Reply #12 on: April 04, 2014, 05:02:22 AM »
Call me and I can be your Son for an hour or so :o    Will there be Cocktails Daddy   ;)
Offline SohRon
« Reply #13 on: April 04, 2014, 05:40:07 AM »
Lots of good info here. If you're completely stripping your bike down to the frame, leave the engine 'til last and use the "flop over" method as described numerous times above; it's a simple, one man job. If you're only pulling the engine, then get a "son" to help you. Work smart and you'll save yourself some grief.
Apparently. Try it sometime, and you'll understand!  ;D
Online PeWe
« Reply #14 on: April 04, 2014, 05:55:37 AM »
That is the easy way to do it. I did it when I put the bike together last year. Engine on side on the bench. Wife helped me to wrap the frame with swing arm over the engine (tubes close to engine covered with old sheet to avoid scratches). Bolts on.
A friend with more muscles helped me to lift and place the frame + engine on the garage floor placed on a pile of wood + jack. Next was to mount roller bearings + triple tree, forks, front wheel, rear wheel.....
I have done it the other way too when I took it all apart. Back in the days when lifting engine only alone.
« Reply #15 on: April 04, 2014, 06:52:28 AM »
I will give it a try someday if I have have to strip one down all the way. promise. I will say watch your fingers if doing it the upright way-- Had a black fingernail from a crush for a very loooong time.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #16 on: April 04, 2014, 10:02:32 AM »
One person operation. Don't even have to take the wheels off....
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline BPellerine
« Reply #17 on: April 04, 2014, 06:23:52 PM »
recip saw just in case?haha bill
1978 CB 750K ard and webers
another anfob
« Reply #18 on: April 04, 2014, 06:30:41 PM »
Used that to cut the "nubs" off of the top of the lower frame mount after the motor was out. Makes going back in a little easier...
every little bit helps!
TAMTF...
Wilbur
Projects:
Offline chewbacca5000
  • I polish covers!
« Reply #19 on: May 16, 2014, 06:23:08 AM »
Where did you get the handle and crank setup?  It looks like turning that handle will pull the engine right out without having to mess around at all.
« Reply #20 on: May 16, 2014, 06:43:25 AM »
That is called load leveler and you can buy one at HF or Amazon or even Pep Boys sometimes.  The lifting is done by the engine hoist, this makes sure the engine is leveled or tilted as needed.
http://www.amazon.com/Heavy-Steel-Leveler-Engine-Hoist/dp/B001P5UWUW
« Last Edit: May 16, 2014, 12:44:30 PM by 70CB750 »
« Reply #21 on: May 16, 2014, 07:04:39 AM »
70CB750 Is correct, it is a load leveler. As the handle is cranked the load will move but it is also tilted at the same time. The more you crank the more it tilts and is really overkill for this application. Besides, it hits the handlebars too, and my hoisting rig has already been modified to eliminate this feature. As long as the lifting point is centered on the top of the jig the load will be level, and in my opinion is easiest too remove (when level). I will post some picts later of the current condition of my lifting jig (without the load leveler). I started with this because I had seen someone else do it this way, but realized it was not necessary.
« Last Edit: May 16, 2014, 01:32:24 PM by madmtnmotors »
TAMTF...
Wilbur
Projects:
Offline frodef2
« Reply #22 on: May 16, 2014, 12:17:40 PM »
Just to shamelessly honk my own horn.
http://forums.sohc4.net/index.php?topic=38654.msg403976#msg403976
This is the link to a post i made back in (2008). it shows a similar tool to what's shown in this thread.
since then i have modified the tool to look like this:
All you need is a nylon strap to loop around the generator cover and around the oil galley. As shown in the old thread.
The extraction of the engine was so easy, i actually took the engine out twice, just to get the pictures.
Frode Johansen
76' Supersport
« Reply #23 on: May 16, 2014, 12:43:45 PM »
Thanks for sharing, I knew I saw it somewhere here.
Offline Peterengland
« Reply #24 on: May 17, 2014, 11:02:50 PM »
I find it easier if everything is off the frame apart from the forks as it will sit on centre stand and me and my mate got it out with no jack or lifter or anything. Really don't understand about laying on its side and lifting off the frame.
