Author Topic: What did you do to your bike today ?  (Read 3775023 times)
0 Members and 17 Guests are viewing this topic.
Offline Dimitri13
  • 1974 CB550K
« Reply #10950 on: June 25, 2012, 11:34:11 PM »
Went into the carbs again. Did a mini-clean. Found that one of the gaskets was pinched. Gonna try a different jet combination for stacks again.
Offline david 750f
  • 1976 CB750F
« Reply #10951 on: June 26, 2012, 01:14:24 AM »
Just went riding  :)
1976 CB 750F
« Reply #10952 on: June 26, 2012, 04:43:52 AM »
I had to deal with the front brake before riding to work. It was locked, got it going but it will need more attention tonight.
Offline WhyNot2
  • I'm finally an
« Reply #10953 on: June 26, 2012, 07:29:32 AM »
Got the bushings out of my swing arm...........and man, looking at some of the ones that have been removed on this forum, mine look like I probably didn't need to change them. The collar looks more beat up than the bushings.
Used the long punch and bfh, got both out with minimal effort.
Guess I should have ordered new bushings................wheres a good place to buy them????????????
Offline Tews19
  • I am no
« Reply #10954 on: June 26, 2012, 09:21:14 AM »
Swapped out my springs last night on the 750, refilled fluid, took her for a ride last night to determine if she is ready for the highway. EXTREME wobble when I let go of the handle bars. Not sure why? It wobbled prior to swapping out the springs too. Then notice this am the left fork was leaking from the 10mm bolt this morning. Tightened it and it snapped. Glad I ordered new fork seals. Will have to rebuild another set and swap out. I do have another pair of k1 forks to do this. One thing I did notice was when I removed the right spring, it was barely covered in oil yet the left side was soaked.
« Last Edit: June 26, 2012, 10:12:22 AM by Tews19 »
1970 Honda CB750 survivor.
Offline Felix
« Reply #10955 on: June 26, 2012, 09:55:48 AM »
I found out how the choke on my CB400F actually works! It rides much better now.
Honda CB500F '72 in progress
Offline Soulsk8r
« Reply #10956 on: June 26, 2012, 11:41:59 AM »
Put her pipes back on, polished her up, and went for a ride on this lovely day.   Life is good.
Newbie rider, newbie vintage bike owner - Honda CB750K1.
Offline mono
  • Definitely no
« Reply #10957 on: June 27, 2012, 08:07:18 AM »
rode mine to work yesterday, then bombed around town for a while after work.   pulled into my drive and lost all pressure on the front brake -- looked down and i was squirting brake fluid from the bleeder like a gushing neckwound.   quick ran into the garage and tightened her down, refilled my brake fluid, and then washed my front wheel off really well.  so glad this didn't happen at speed, cause i would have had brake fluid sprayed all over the bike!   :o   but no harm no foul!
Offline Sniper X
  • Resistance is not futile, it is voltage devided by current.
« Reply #10958 on: June 27, 2012, 08:13:57 AM »
Well it wasn't today, but last night I cleaned all the crap off the fenders with never dull, used cleaner wax on the master cyl and idiot light pod (both came back to black), and cleaned the pipes. Just this stuff made about a 75% looks improvement in the appearance of the Little Jewell (CB350F). AND I rode the R80RT (BMW) down to the car wash and cleaned off about five years of previous owner neglect in washing the bike. He is a great rider and maintained it in an excellent manner mechanically but neglected the looks and such. I also used plastic polish on the windscreen and my polisher and it is now so clear I can use it to look thru instead of having to look over it.
1973 CB350 Four, 1969 CL350 Scrambler (2) 1985 BMW R80RT.
Offline longshanks
« Reply #10959 on: June 27, 2012, 11:50:45 AM »
I had bad wobble before too until I replaced my fork seals and got new tires and had them balanced and rotated. I do think however, that the tires made the most difference. Mine is super smooth now. I can go 80mph and deaccelerate with no hands and its SOLID.
cb450 K5
Offline CycleRanger
  • No comment about being an
« Reply #10960 on: June 27, 2012, 12:36:26 PM »
Since one of them was leaking on the concrete I drained the ATF (Albacore Tuna Fish) oil out of the forks from the CJ360T...
Offline Tews19
  • I am no
« Reply #10961 on: June 27, 2012, 01:19:17 PM »
I am pretty sure I found the problem. The but under the unicorn triple wasn't tight. I will give update once I swap out the fork
maduncle
« Reply #10962 on: June 27, 2012, 04:52:39 PM »
Ah - that'l be it then.
Nothing like a loose but to make riding uncomfortable.
« Reply #10963 on: June 27, 2012, 06:13:25 PM »
The unicorn's butt was loose? Don't tell me how you found that out!
Offline Tews19
  • I am no
« Reply #10964 on: June 27, 2012, 06:28:15 PM »
The one under it! I called all balls and explained the issue. They told me i need to torque it to 25 ft lbs
Offline DJ_AX
« Reply #10965 on: June 27, 2012, 06:35:48 PM »
On the afternoon shift for the summer.
3am. Ride home on the 750. The longer twisty way.  In almost 40 miles I only saw a few cars the whole way! Perfect!
3pm. Took the cover off of the 550 and put it on the 750. Rode the 550 to work. Looking forward to the ride home! :)
Offline Hablo
« Reply #10966 on: June 27, 2012, 09:46:32 PM »
Did a little tune up...points, timing, valve lash, cam chain, and carb sync.  Ready to roll out to Born Free 4 on Saturday.
'73 CB350F
« Reply #10967 on: June 27, 2012, 09:48:40 PM »
Cliff, i'm not really sure i want to know this but, how did you end up with a loose butt.... ;D :o
maduncle
« Reply #10968 on: June 27, 2012, 10:30:17 PM »
Well - y'see, I have this good mate Terry...
Offline letutt
« Reply #10969 on: June 27, 2012, 11:19:50 PM »
I got a phone call from Spring Works in Woods Cross, Utah.  They are done making my custom springs for my 550-four.  I went with something a bit stiffer that also bottoms out a bit later than stock.  I'm stoked!  Picking them up in the morning.  The front end of my 550-four is from a 1967 cb450 for a very classic look.
« Reply #10970 on: June 28, 2012, 12:07:04 AM »
Someone told me Terry was a pain in the ass, i never would have guessed..... :P
maduncle
« Reply #10971 on: June 28, 2012, 12:20:23 AM »
Pictures please - I am keen to see how the classic CB450 front forks look.
Are they external spring forks?
maduncle
« Reply #10972 on: June 28, 2012, 02:47:50 AM »
Meanwhile - what did I do on my bid today?
The clutch.
As in - I got on my VFR750 to go out tonight and found I have no clutch.
« Last Edit: June 28, 2012, 02:26:07 PM by maduncle »
Offline WhyNot2
  • I'm finally an
« Reply #10973 on: June 28, 2012, 03:50:58 AM »
Finally got notification that the chain I ordered for my 750, is finally being shipped after almost a month waiting.
Now I better order those darn bronze bushings, but can't make up my mind which ones::::::
Thoughts.....anyone.....anyone
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #10974 on: June 28, 2012, 04:32:16 AM »
I think the shouldered bushings are for the later (77/78) models, unless that's just a generic photo.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
