Author Topic: Helicoil in stripped caliper/fender bolt holes on Left fork lower  (Read 3293 times)
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
Turns out my PO was trying to kill me!
Got my new fork tubes from CycleX all nice and installed
Then I am installing the left side fender/caliper bolts (6mm), and they just keep turning and tuuuuurning... FACK.
Them's some nice stripped out holes. Might even have been some remains of blue loctite... BAH. The 8mm on bottom is fine, thankfully. That is what kept me alive these past three years of ownership!
Has anyone successfully Helicoiled these holes before? This is really my only option at this point... other than a plug weld and re-tap, but I don't want to alter the structural integrity of the fork lower by adding so much heat.
--Evan
1975 CB750K "Rhonda"
Re: Helicoil in stripped caliper/fender bolt holes on Left fork lower
« Reply #1 on: February 22, 2016, 02:48:25 AM »
I do not see the photos.
I also have bad thread in one of the holes in the fork keeping the caliper bracket. I used a longer bolt + blue loctite if I remember correctly. I'll repair it better before sping. Either helicoil type or Time-sert. I think I'll do the time-sert.
Offline evanphi
  • Apparently I'm an
« Reply #2 on: February 22, 2016, 03:02:13 AM »
I tried a longer bolt, but only got 3mm worth of good thread. Not enough.
--Evan
Offline evanphi
  • Apparently I'm an
« Reply #3 on: February 22, 2016, 03:40:50 AM »
If you feel confident, drill the hole for a larger bolt (8mm) then tap with a standard pitch. There's ample meat on the boss for a larger hole. You'd be drilling for a helical anyway, and there's little harm in upsizing your bolt.
I thought about that... what say you about these though? Seems like there isn't much on the inside of the bosses for some reason.
--Evan
« Reply #4 on: February 22, 2016, 03:52:32 AM »
Evan:
Yes, I did helicoiled all 4 M6 on Dorothy's lowers.  I got tired of loosing those M6s too :), every so often there would be one missing.  I bought metric helicoil kit on ebay, since it was cheaper than couple of singles.
Anyway, helicoiled, put some serious miles on it and when I took her apart everything was still holding well.  I did not feel like going one size bigger because of the brake arm holes.
Offline evanphi
  • Apparently I'm an
« Reply #5 on: February 22, 2016, 04:10:02 AM »
This is the other thing, I don't want to get into drilling EVERYTHING. I can get a M6 Helicoil kit for 30$ locally. Drill out the holes with 1/4" bit, tap, and insert. Whew.
--Evan
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #6 on: February 22, 2016, 04:24:46 AM »
+1
Helicoils are easy, especially since you are only drilling and tapping aluminum. The Helicoil threads are much stronger than the original aluminum. I usually give the new thread coil a drop of red locktite prior to insertion and then will use antisieze on the bolt just to keep the red locktite from grabbing the bolt. You might be able to use the bracket as a drill guide, but make sure the hole in the bracket will accommodate the drill bit. I do not recommend enlarging the hole in the bracket.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline RRRToolSolutions
  • I love old Japanese bikes!
« Reply #7 on: February 22, 2016, 04:43:07 AM »
Guys, I would fix those with Time-Serts. I've used these for years to repair threads like these.
Gordon
http://www.timesert.com/html/install.html#
http://www.timesert.com/index.html
Kaws, Hondas, Yamahas, and Suzukis - especially Kaws
Offline Flyin900
« Reply #8 on: February 22, 2016, 05:39:22 AM »
+1 on the Time Sert.
Best repair you will ever do and you will only ever do it once. Not as cheap as a coil... But you get what you pay for IMO.
Will have to drill a larger hole though for the Sert, so that seems to be an issue for the poster.
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
Offline mystic_1
  • 1970 CB750K
« Reply #9 on: February 22, 2016, 06:22:41 AM »
No bigger than the one you'd be drilling in order to install a helicoil.
I like timeserts because they seem stronger to me, but that's just a feeling.  The also look nicer when installed, which appeals to my OCD side  :D
Either way you go, be aware that you should drill out the old threads completely, to the bottom of the hole, so they don't interfere with your new bolt when you go to install it.
Also make sure there's enough depth to the holes for the insert your are using, both helicoils and timeserts are available in different lengths.
mystic_1
- John Augustus Shedd
« Reply #10 on: February 22, 2016, 07:17:57 AM »
Time-Sert is not cheap but needed. Big-Sert cost some more but will help when welding is another alternative.
I have ordered from here: http://www.ebay.com/usr/threaddoctor
Time-Sert when the thread goes bad, Big-Sert when the helicoil has gone taking the alu on the way up.
I fixed 2 cam tower studs threads in the head where the helicoil went up. Big-Sert + loctite 272 solved it.
Offline Kenzo
« Reply #11 on: February 22, 2016, 07:43:09 AM »
If just a single disc system...couldn't he switch the forks, move the caliper to the rear location and leave the stripped slider threads unused?
Kenzo
H-Town, Tejas
>1976 CB550F SuperSport (Work In Progress)
MotoGP Werks Exhaust, Uni Pods
>2006 KTM EXC 453 (EXC 400 w/ Short Stroke Big Bore Kit)
« Reply #12 on: February 22, 2016, 08:29:40 AM »
I just made this repair two weeks ago. Took longer to remove the front wheel and fender than it did for the ten minutes it took to install the Helicoil.  8)
TAMTF...
Wilbur
Projects:
Offline jonda500
« Reply #13 on: February 22, 2016, 07:37:17 PM »
I like helicoils, I have a 500 with many helicoils fitted and so far none of them have failed, John
A starter clutch thread:
Offline evanphi
  • Apparently I'm an
« Reply #14 on: February 23, 2016, 08:24:15 AM »
Did the helicoils today!
--Evan
« Reply #15 on: February 23, 2016, 08:42:31 AM »
Looking good! Makes you wonder what you were worried about before?
Even has the first coil turned in past the first thread as it should be.  8)
TAMTF...
Wilbur
Projects:
