Author Topic: Blew Oil Filter, Ran Un-lubricated now Top Ticking and Lack of Power  (Read 7469 times)
Offline mkoski
Cross-post from my build thread to reach a wider knowledge-base.  :)
Hi guys,
Sunday night I was out for a ride and heading home when I lost oil pressure around one mile away from my house. I was on a major road with a high speed limit when I noticed my engine began to lack power and run a little funny. This lack of power was accompanied by a fairly loud ticking in the top end of my engine almost immediately after the power loss was noticeable. I made an exit and noticed that at idle I had to give some throttle to keep the engine running. This felt like I was fighting piston/sleeve friction.  :( I brought it into my garage. I tried using the electric starter to turn the engine over and it would not turn. Unbeknownst to me at the time, my oil filter on the front had ruptured and caused me to lose a lot of oil. I left my bike to cool for the night after looking in the oil tank, confirming that there was no oil.
Yesterday morning (Monday) I went to my bike and hit the electric start. The engine turned over no problems and seemed to sound okay. I did not start it as it had no oil. After work I picked up a bunch of oil and went home and changed the oil twice and also the oil filter. I didn't find any obvious signs of metal in the oil. I fired the bike up after circulating oil with the starter for a bit and it started fine and seemed to sound okay, besides slightly-louder-than-before valve-train sounds. I revved it up a bit and it sounded fine so I took it for a ride. While riding I could feel the same symptoms of when I was riding home Sunday night. A loud ticking sound was apparent when the engine was under load. The bike would rev up more slowly and produce very little power.
So my question to you guys is this: from the lack of power and ticking in the valves when under load I am sure I need to do a top-end rebuild/inspection. What else should I look for and what specifically do you guys think is causing this issue? My best guess thus far is that a valve or rocker is stuck/damaged and this is causing a cylinder to not fire, causing the lack of power. Does that sound right?
Tonight I am going to remove tappets to check valve clearances and make sure nothing is loose then test compression across all four cylinders. This should give me some idea of what might be wrong.
Re: Blew Oil Filter, Ran Un-lubricated now Top Ticking and Lack of Power
« Reply #1 on: June 09, 2015, 08:56:23 AM »
Sorry...this sucks to hear.  :-\
Even without an oil filter, you will get circulation.
Oil travels from the exterior of the filter, to the interior, and thru the cover bolt ...
Are you sure your oil pump didnt shiit the bed?
All the oil being in the sump makes me question the pump, or an oil blockage somewhere, not the filter itself.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #2 on: June 09, 2015, 08:59:18 AM »
From the other thread I gather that the "rupture" was external = most of the oil was lost/ran dry = not good.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline mkoski
« Reply #3 on: June 09, 2015, 09:03:38 AM »
Correct, I was using a spin-on filter and the rubber seal around it gave up.
« Reply #4 on: June 09, 2015, 09:04:38 AM »
so all the oil blew out onto the road?
(I didnt gather from your original post that this was a spin-on filter.  Understood it as the filter in the housing gave up)
« Last Edit: June 09, 2015, 09:08:28 AM by flybox1 »
Offline mkoski
« Reply #5 on: June 09, 2015, 09:08:18 AM »
Thats the funny thing, I never noticed any oil leak! Might have been a slow (ish) leak that finally drained the last of the oil.
I know (or at least am pretty sure of this) that it was the filter, though, because last night I refilled the oil tank and idled my bike for a while. After it warmed up a bit I brought the RPM up a little and oil sprayed out the side of the filter 10 ft away from the bike, and a decent amount of it too.
« Reply #6 on: June 09, 2015, 09:15:36 AM »
I always used Bosch as a spin on filter, but the last oil change, I just could not get it tight enough.  Spent the money on K&N because you can get socket on the filter and drive it in.  Other than that, never had any problems with spin ons.
Anyway, your engine:
- pull the oil pan and check for debris in it.
- set cam chain tensioner
- set valve clearances
Take it for a spin , chances are it will be just fine.  Are all exhaust pipes hot - are all cylinders firing?
« Last Edit: June 09, 2015, 09:17:26 AM by 70CB750 »
« Reply #7 on: June 09, 2015, 09:17:12 AM »
wow...ok.
Id ditch that spin-on and go with a standard filter and housing before more damage is done.
Pour at least a quart of oil up top before starting it again.
IIWY, valve cover needs to be removed for top end inspection.  cam lobes, rocker faces, cam tower seats...etc.
« Reply #8 on: June 09, 2015, 09:21:24 AM »
Next time you start it up check the head pipe temps with a wet rag to see if all 4 are still firing, symptoms sound like you may not be and its quick and easy to verify.  Sorry to hear about that problem.
« Reply #9 on: June 09, 2015, 09:29:08 AM »
I always use my fingers  :(
Wet rag - now thats a novel idea  ;D
Offline mkoski
« Reply #10 on: June 09, 2015, 09:40:45 AM »
I love to use my fingers too, really clear on which ones are hot.  :)
I tossed my spin-on filter and put the stock housing back on with a new filter element. The security of a nice tight bolt makes me sleep better after this incident.
Here's my plan:
As per ekpent/70CB750 I will start by running the bike and checking pipe temps as a preliminary.
Next, if I am not firing on a cylinder I will do a compression test and then test again after adding oil to the cylinder. (Ghetto test of rings or valve causing the leak). If the cylinders are all running equally then that's going to be an interesting twist...
During that process I will open up tappet covers to ensure everything is secure, clearances are set and that everything looks okay.
I really dont want to take off the cover as that means I am removing the engine from the frame. I think the odds of this are high though, so I am realistic. If I can get everything to run smoothly again I wont pull the engine but I will change the oil frequently and be very mindful of whats coming out and the sounds of the engine.
The ticking at the top end really makes me think a valve got eff'ed up though so we shall see what results yield, I'll keep you guys up to date.
« Reply #11 on: June 09, 2015, 09:45:36 AM »
Good luck!
Somebody demonstrated that it is possible to take off the valve cover with engine in the frame if you remove the breather cover first.
Just saying  :)
Offline mkoski
« Reply #12 on: June 09, 2015, 09:50:14 AM »
Good luck!
Just saying  :)
Thanks, I'll need it! And you bet I'll be trying that before I pull the engine!
What a thing to happen on the day I officially completed the build and after riding 2000 km on that filter...  ::)
« Reply #13 on: June 09, 2015, 10:17:20 AM »
Shenanigans I say!  ;D   Unless you have a frame kit, or a 500/550, I dont think it is possible.
Offline CycleRanger
  • No comment about being an
« Reply #14 on: June 09, 2015, 10:20:08 AM »
I had this happen too.
Fortunately it occurred before I left the garage.
It was not Bosch filter.
Unfortunately it blew oil all over the hot pipes and the garage.
I switched back to the stock filter setup.
« Reply #15 on: June 09, 2015, 12:02:58 PM »
I haven't had issues with my spin-off filters on both of my CBs.  I wonder if it is luck of the draw or quality control with Phram and Bosch.
10 foot spray pattern!! I bet that oil leak left a slippery road slick on your ride.  Yikes!  :o
Offline Airborne 82nd
« Reply #16 on: June 09, 2015, 12:26:36 PM »
I read where some people found the oring to be too thin even with the OE canister type. But not with a genuine Honda filter.
Offline mkoski
« Reply #17 on: June 10, 2015, 08:56:53 AM »
It was this guy, famous for causing problems I have learned:
Fortunately that oil blow-out occurred in the garage. I never saw/noticed the oil leak while riding.
« Reply #18 on: June 10, 2015, 09:05:30 AM »
 I'd be surprised if it didn't wipe a cam lobe and rocker, or the aluminum the cam rides on. Checking the lash will tell the story of the cam lobes/rocker surface. If you love this engine and one or more have excessive lash I'd pull it apart with as little running as possible.
« Reply #19 on: June 10, 2015, 09:32:14 AM »
I used that one once and spent year to find a replacement in local chain stores.  AFAIK it is only available from vintagecb750.
« Reply #20 on: June 10, 2015, 09:47:21 AM »
When hot, what is the average pressure generated by the oil pump under normal riding conditions?
(I dont have a pressure gauge on my 750 )
Is that ^^^  pressure enough to blow oil 10' out the side of a filter? (Fluid dynamics is not my thing)
If the answer is NO, couldnt you surmise there is a blockage somewhere in the oiling system which cause added pressure/blowout?
I dunno....this just got me thinking.  I wouldn't jump to the conclusion its the spin-on filter  ???
Offline strynboen
« Reply #21 on: June 10, 2015, 09:48:38 AM »
have you not a OIL light ..?
i hate all this v-w.... vords
« Reply #22 on: June 10, 2015, 09:50:56 AM »
Hot engine 20psi idling, 60 or so psi riding.
Offline CycleRanger
« Reply #23 on: June 10, 2015, 09:58:02 AM »
Bingo! That's guilty party in my case as well.. >:(
« Reply #24 on: June 10, 2015, 09:59:27 AM »
The oil seal is much thicker on that one than on regular automotive filter.
