Author Topic: Keyless Gas Tank Options?  (Read 13288 times)
Offline DaveBarbier
Re: Keyless Gas Tank Options?
« Reply #25 on: May 28, 2017, 02:06:18 PM »
Well the quik-latch came yesterday, holy crap that was quik! :)
Just finished the install. Pretty dang easy and I think it looks awesome. It also works perfectly. For the last time, thanks Alabama for the suggestion! I highly recommend this if you don't want to carry keys. Here are the pictures.
I turned up a piece of steel to fit in the hole in the receiving end of the tank. Here's the threaded plug.
You can tell that it's been welded in and painted. I have a nut on the underside locking the post. So it's essentially double nutted.
Video of it working:
Offline Smudgemo
  • Maker of Stuff
« Reply #26 on: May 28, 2017, 02:08:41 PM »
Love it!
-Ryan
Thread - How to fix your starter button (for real): http://forums.sohc4.net/index.php/topic,163170.0.html
Offline jamesw
« Reply #27 on: May 28, 2017, 02:12:18 PM »
Make this a sticky. The key lock is often missing from tanks.
What was the total cost?
72K-F 750 Cafe
75K 750 Cafe
75F 750 Restoration
Offline DaveBarbier
« Reply #28 on: May 28, 2017, 03:41:08 PM »
Total was $30. It was really nice because the OD of the threaded part is .75" and the existing hole in the tank is a hair larger. Like .76" or something similar. Fits like a glove.
Offline Jimray23
    • none
« Reply #29 on: May 28, 2017, 04:19:38 PM »
I don't lock my doors, haha. Some people I know lock their doors when they're home like in the day time, like a Saturday afternoon, that's crazy to me.
I agree but, i have 8 large dogs in my house and yard, i don't really need a lock.
Jim
1979 kz1000b ltd
    stage 3 cams
    pod air filters
    4-1 open exhaust(no muffler)
    full rewire
    dyna-s ignition
    dyna 3 ohm coils
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #30 on: May 28, 2017, 07:57:22 PM »
That's almost exactly how I imagined!  8)
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #31 on: May 29, 2017, 01:25:21 PM »
Finally Wilbur, you've come to your senses and are now dreaming about a 550!  ;D
I have been looking for a pit bike...  :-\   ;)
TAMTF...
Wilbur
Projects:
« Reply #32 on: May 29, 2017, 02:49:49 PM »
Dave,
I was confused in my old age. By key-less I thought you meant something like an RIFD key-less system -- instead of a latch/fasterner to replace the need for a key.
I like the solution Alabama suggested.
That would be a little too much electronic-ness for even me, haha. A simple push button is what I'm after.
And it came out looking great, too.
Offline AlabamaCB750
  • Competent CB750K2 Owner
« Reply #33 on: May 29, 2017, 09:08:29 PM »
Wow! Looks like it came that way! Beautiful simplicity.
Online Stev-o
« Reply #34 on: May 30, 2017, 09:22:25 PM »
Great job, Dave. Patent it!
Offline parm94
« Reply #35 on: May 31, 2017, 04:23:06 AM »
Top notch work, looks real slick.  8) I'll be using one for my new tank.
Offline DaveBarbier
« Reply #36 on: May 31, 2017, 04:27:55 AM »
Thanks guy, yeah I'm a big fan.
And a few people have asked, but I used the 1" size because that looks almost perfect over the raised bump. I did turn it down about .030" on my lathe but it wasn't necessary. So it went from about .990" to .960".
Offline Mr Freeze
« Reply #37 on: June 01, 2017, 02:52:19 PM »
This is excellent and I'm going to be doing this on my ride.
Offline Fezzler
« Reply #38 on: June 22, 2017, 10:03:48 PM »
Thank you for the great idea.  It will be nice to eliminate that gas lid key.
My Quik Latch arrived after only a few days.  QL-25-S1 Billet Mini Quik-Latch 1 Inch Upper Diameter.  $29.
After removing the lock and latch for the Honda key I first screwed in the push button.  Looks great and like it was made for the bike and this purpose.  (Wondering if it would be wise to use a small gasket between the button and gas lid?)
For the post, I had to get creative.  (This is where Cal thinks "oh no" and pulls over to the side of the road to read the post.  Don't worry Cal, no cheap HF drills or bits were employed.)
After several failed ideas, I finally arrived at using the old key switch clip, but putting the latch post between the original clip.  Then I found two nicely sized hard plastic washers in my extensive and neatly organized parts cabinets  (Cal - shhh!).  I cut the post down with a saw of some sort.  Then I used the two nuts that came with it to sandwich the original key switch latch between the washers.  Works great.  I need to fine tune a little, but done.  Key is the part of the post that needs to be sticking up to clip to the latch, the bottom of it needs to be flush with the top of the Honda key latch clip holder.
Pictures below.
1975 Honda CB550f in parts in progress
1978 Honda CB550 Four K4
1971 Honda CB500 Four K0
2008 105th Anniversary Edition HD Road King
(Sold) 1998 Honda Shadow ACE Deluxe VT750
1973 Schwinn Stingray (Blue Deluxe - RIP Jack and Rose)
Offline DaveBarbier
« Reply #39 on: June 23, 2017, 04:46:19 AM »
Nice looks good. If you do have opening issues at least it looks like you have complete adjustability.
If you want to go nuts, you can disassemble the latch. The underside has two small holes in a stainless threaded sleeve threaded in with red loctite. I used my propane torch and snap ring pliers to get it out. (Normal threads, not left hand threads.) Remove that part but watch out for the three small ball bearings that should be stuck in with grease. Remove the spring and button and then you have a hollow latch. Install the latch back on the tank and you can see the alignment of the post and move it accordingly. Reassemble with red or blue loctite. I used blue.
Offline Fezzler
« Reply #40 on: June 23, 2017, 04:59:14 PM »
I'll keep that in mind.  For now, no key and it works.  Opens and closes securely.  But who knows, I may get the desire to perfect.  Your switch does seem to work more smoothly than mine.  Alignment I bet, as you say.
Offline tekkie
« Reply #41 on: July 23, 2018, 04:19:48 PM »
thanks for posting this i am definetly doing this as my lid was missing and the replacement has no luck
