Author Topic: Sorcerer and Atchison, Topeka and Santa Fe to be restored  (Read 543530 times)
Online scottly
Re: Sorcerer and Atchison, Topeka and Santa Fe to be restored
« Reply #3050 on: August 14, 2018, 09:42:04 PM »
No buttons....the oil ring is in the wrist pin hole....they moved it up for the stroker. F'ing pistons SUCK to install.
I hope you're using 1 piece oil rings; 3 piece need more support, like buttons with a ring groove.
« Reply #3051 on: August 14, 2018, 09:45:24 PM »
Really suck to install.
x 3, right? (12 pistons)
Offline blacksmith1
« Reply #3052 on: August 15, 2018, 02:40:04 AM »
wow,Russ Collins was a bloke i respected greatly,still have the cycle guide mag from the 70's when i had my near new k2,awesome machine
Offline NitroHunter
  • Radical Street / Strip Turbo
  • A man's motorcycle is a reflection of the man
« Reply #3053 on: August 15, 2018, 08:39:37 AM »
No buttons for the pistons as the pin hole has been moved up into the oil ring groove to accommodate the stroked cranks.
Mike just curious, if you cut buttons to match the ring groove are they so small it would rock and pinch the rings?
Robbie the NitroHunter                      Fuel Coupe Hired Gun                  NHRA T/F 640
DRAGBIKE USA XH/MB Recordholder: http://forums.sohc4.net/index.php?action=dlattach;topic=127179.0;attach=332735
DRAGBIKE USA XH/SS Recordholder: http://forums.sohc4.net/index.php?action=dlattach;topic=63940.0;attach=103300
Young mans glory days in the lanes: http://forums.sohc4.net/index.php?action=dlattach;topic=45685.0;attach=66341
« Reply #3054 on: August 15, 2018, 07:33:19 PM »
Rob....the pistons use c clips. They are Venolia's from back in the day. 2mm iron top ring.....even the guy at Total Seal couldn't believe it.
Online scottly
« Reply #3055 on: August 15, 2018, 07:42:16 PM »
What about the oil ring, Mike? Regardless of the type, there will be a potential leak past the ring in the open pin area.
« Reply #3056 on: August 15, 2018, 09:07:44 PM »
I didn't rebuild the heads or work the cylinders. I received 3 sets of Total Seal rings with the pistons. The oil ring is 2.5mm 3 piece. Top ring 2mm, 2nd 1.5mm. I can get the thick rings to aid in maximum sealing/ heat transfer from the piston (using nitromethane).
 I am not concerned about some oil getting past the open pin area...that thick scraper ring will pick it up and these aren't touring engines. The amount of unsupported oil ring is not very much and with the thickness being 2.5 mm it is still pretty stiff with the large expander sandwiched between the rails. Being in the very top of the wrist pin there isn't much piston thrust working on that area.
 Believe me....there are lots of compromises with these engines. I did the best I could solving the backing plate/oil leakage problem (which was a real BIG problem) with permanently attached CNC'd 1/2" aluminum plates on "new cases". The cases are far more robust and you won't have to RTV a red shop cloth INSIDE the back of the engine. And yes....that did happen. There are lots of other things too which have had me pulling my hair out at times. Home stretch now with just bolting on the heads on #2 and #3 and timing the cams. Waiting for #1 crank to return to me.
« Last Edit: August 16, 2018, 02:36:15 PM by MRieck »
« Reply #3057 on: August 16, 2018, 06:14:11 PM »
While at Mike's, he ran through some of the obstacles he's faced with these and it's not a job for the faint of heart!
I must say the ingenuity involved designing the rear cover plates to seal those cases is impressive.
Online scottly
« Reply #3058 on: August 16, 2018, 08:20:32 PM »
Somehow I had envisioned the oil rings across the center of the pins, not at the top. ::)
« Reply #3059 on: August 17, 2018, 05:00:50 PM »
That would be quite a difference in stroke BUT with this stuff anything is believable! ;D
Offline Bill/BentON Racing
    • BentON Racing
« Reply #3060 on: August 28, 2018, 04:09:24 AM »
Hell yes, that RC cylinder with no champher,  I made up new 4 letter words and then some! Really F'in Frustrating! You nailing it bro, knew you would,  told Jr. that a long time ago in Valdosta.....so glad you two teamed up and he got to meet our secret weapon Keith  ;D, lol. Been a fun ride, all Sam Green's fault! LMAO,  Good luck Mike, builder of the year!
BentON Racing Website
BentON Racing Facebook
« Reply #3061 on: August 28, 2018, 05:26:37 AM »
Thanks Bill. The #1 crank left Marine Crankshaft
yesterday. Cleaned out Kenny's stock of hardwelded rocker arms....the 1 set that arrived with the parts were beat and the other 2 sets MIA.
  • Moderator
« Reply #3062 on: August 28, 2018, 05:35:14 AM »
Somehow I'ts always my fault, hahahaha.
But hey Mike, you got one hell of a good write up on Facebook today from Junior.
Russell W Collins Jr
11 hrs
Mike Rieck is up to cam timing on the Triple...beautiful work, impeccable machining and finishes. Picked the right guy for this! The last crankshaft is on its way back to him for assembly on the last of the three engines. Folks...this is " game on" for the next and final phase of this incredibly complex task.
Offline kap384@telus.net
« Reply #3063 on: August 29, 2018, 01:37:30 PM »
11 hrs
Awesome news!
1965 Honda CB450K0
1972 Honda CT70K1
1975 Honda CB400F Supersport
1977 Honda CB750F2 Supersport
1978 Honda XL100
1979 Honda CBX Supersport
1982 Honda VF750S Sabre - Adventure Bike modified
1983 Honda CX650T
1995 Honda VFR750
2016 Honda CRF1000L Africa Twin
2015 KTM 200 XC-W
1963 Suzuki T10
My 1977 CB750F restoration - http://forums.sohc4.net/index.php?topic=66779.0
My 1975 CB400F restoration -
http://forums.sohc4.net/index.php?topic=145196.msg1651779#msg1651779
'More Stock Than Not' thread - http://forums.sohc4.net/index.php?topic=90807.500
My CT70 Resurrection - http://forums.sohc4.net/index.php?topic=145221.0
Best Motorcycle Tool Ever - https://www.engduro.com
  • Moderator
« Reply #3064 on: February 03, 2019, 03:16:34 AM »
Well guys, it seems like the motors for the AT&SF are complete and are now somewhere at a secret location in Georgia, well done
 Mike.
« Last Edit: February 03, 2019, 05:04:44 AM by Sam Green Racing »
Offline gschuld
« Reply #3065 on: February 03, 2019, 04:23:06 AM »
Nice going Mike👍  I know you put a PILE of time reinventing the wheel to make these truly worthy of the original NHRA best engineered award it received😉
George
« Reply #3066 on: February 03, 2019, 07:32:09 AM »
Mehh, not bad.     ;D  ;)
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #3067 on: February 03, 2019, 12:12:20 PM »
Rock on!
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline dragracer
  • CB750F Dragbike
« Reply #3068 on: February 03, 2019, 10:27:20 PM »
 Mike.
Hmmm, in Georgia you say? Only  3 possible places down there I could imagine those engines showing up. Star Racinh with George Bryce ( but he's Harley only now), Cooper Performance(but he doesn't do chassis work), and finally there's Timblin Chassis. So i'll take Timblin Chassis as my choice. Lol
« Reply #3069 on: February 05, 2019, 02:54:06 AM »
Outstanding Mike! Love the crate ;)
cheers
Andy
« Reply #3070 on: February 05, 2019, 10:07:03 AM »
Beautiful. But Frank, there is one other place......
Offline gschuld
« Reply #3071 on: February 05, 2019, 11:11:21 AM »
You figured it out Jerry.  Billy is right now trying to figure how to shoehorn that triple package into Cobra Girl👊
George
« Reply #3072 on: February 07, 2019, 12:56:25 PM »
George
Thank you George. It did take a lot of time to re-engineer those engines. Eventually I figured I had to start from scratch in regard to the cases. Other parts needed a lot of attention.
Offline y2kc0wb0y
  • B00msh0cka
  • Shoot the pickle....
« Reply #3073 on: February 08, 2019, 05:45:15 AM »
I've said it before on this thread but given the amount of restoration this has required, the OG bike(s) truly deserve to be in motorcycle engineering hall of fame. The time frame the original bike(s) were built under show pure genius at every level of the sport.
CB750K3 890cc| 2004 VFR800A| 76 CB550F| 77 CB750F| 73 CB350G| 79 XLH| 2007 BMW R1200GS| CB750K2
Offline gschuld
« Reply #3074 on: February 08, 2019, 07:42:50 AM »
True, and unfortunately the need(strong desire) to design and build such a complicated bike in such a short time frame didn’t allow for anything resembling an ideal R&D process.  This bike was considered as a short lived promotional/bragging rights, dominating, chic magnet monster.  Technology was moving rapidly back then.  As a result, the time needed to really custom engineer many of the parts was just not available.
For example, Mike’s work to finally build proper engine cases with CNC machined rear block off plates(all 3 engines were crank on up assemblies, no trans, clutch, shifter, etc) is a work of art in itself.  The original method was a bit more....simplistic😉
