Per the ad it's a 55/60 watt H4 HID bulb. I think this taxes the 550 electrical system.
It's the upper end sure, but I'd be more concerned about the quality of the wiring (too small a gauge?) or a cheap connector. I've never bought anything with the name Emgo on it that wasn't an absolute piece of CR@P!
If you're blowing fuses, your over-drawing the fuse. What size fuse are you running for the head light? And have you made any mods up front where the Head light circuit is also powering something new/extra?
Well, I'm not blowing fuses. Just the low beam is burning up. Haven't blown a headlight fuse yet. I'm sure if I kept the high on that would blow too. It's a 7.5 amp blade fuse. I don't think they come in just 7 amp which the original glass fuse was.
No mods, the headlight circuit isn't powering anything else...there is a wire tapped into the high beam connector for the LED high beam indicator, though, but that's stock.
I've read a bit of the 60/55 watt bulbs taxing the system, but then it would melt wires or blow fuses, not blow the bulb, right?
