Author Topic: What did you do to your bike today ?  (Read 3649844 times)
Don R and 4 Guests are viewing this topic.
Offline Dimitri13
  • 1974 CB550K
« Reply #11650 on: August 20, 2012, 10:54:46 PM »
Finally welded the reducer to my exhaust pipe. First time ever welding and I didn't practice on some scrap metal like I should have. Didn't come out bad, but it's definitely going to need an exhaust wrap.
Markcb750
« Reply #11651 on: August 21, 2012, 02:05:28 AM »
Plugs & Points.  adj valves.  Oil change yesterday.
Gasket on the airbox is unsalvageable.  I have been nursing it since putting a K8 airbox on my k6.  Apparently the gasket was made from unobtainium; so far I have not even found a part number (CMS sells a complete airbox for 171 euros !2 left!.)  Guess I will need to look in the bins above the garage doors to see if one of my salvage air boxes has a useable gasket.
« Reply #11652 on: August 21, 2012, 02:32:38 AM »
What about a thin strip of wet suit material Mark? Just glue the shiny side into the recess and it should provide a really good seal. Cheers, Terry. ;D
Markcb750
« Reply #11653 on: August 21, 2012, 02:43:15 AM »
I may be doing something like this tonight.  I was thinking some EPDM tape but I doubt I will ever wind surf again, the wet suit can go.   :)
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #11654 on: August 21, 2012, 04:08:37 AM »
I went with type #1 in neoprene, 1/8"x1/4"x1/4" item #8507K43: http://www.mcmaster.com/#catalog/118/3769/=ixzfav
The "D" dimension (5/16") is too deep, but I plan to trim down the leading edge for proper fit. Enough to do three air boxes for less than ten bucks.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #11655 on: August 21, 2012, 06:22:24 AM »
Installed front fender.
Ride to work was dreamlike due to heavy fog.
Offline the technological J
  • deliciouso!
« Reply #11656 on: August 21, 2012, 07:16:31 AM »
after deciding my 74 engine needed work i started into my 2 spares that came with only to find that they are stuck.. after trying to toss one aside it rolled back on my shin... and is still stuck
94 ST1100..Gone
72 750 K2 Stay tuned!
Offline apetersonboy
  • 1978 CB 750F SS
  • Slow and not very steady.
« Reply #11657 on: August 21, 2012, 07:51:49 AM »
De-Rusted my 1978 CB750F SS gas tank with The Works toilet cleaner then re-sealed it with Red-Kote gas tank liner from Dime City Cycles!
Offline bjatwood
  • I never claimed to be an
  • 1973 CB750-K3
    • Minbikers Proboards
« Reply #11658 on: August 21, 2012, 10:17:12 AM »
After 37 years of motorcycling, I finally took an advanced riding course and got my "M" endorsement! The CB ran and handled the course with style and grace. I even got the "Oooo Sooo Smooth" award being the best rider out of a dozen veteren riders. It won me a 24 hour Harley rental certificate..... :o
When I started riding bikes back in the 70's you just needed a drivers license, now a days it's a bit more than that... 8)
Brian
#24193
I believe that the Finest things are the most thoughtfully made, not the most expensive!
http://minibikers.proboards.com/
Offline Really?
« Reply #11659 on: August 21, 2012, 10:19:03 AM »
¡ʞɔɐɹɟ  ˙uıɐɹ ɟo ǝɔuɐɥɔ %06 pıɐs ʇı ʍɐs ı ʇnq ʎɐpoʇ ƃuıpıɹ ʇnoqɐ ʇɥƃnoɥʇ  ˙ǝƃɐɹɐƃ ǝɥʇ oʇuı oƃ uǝʌǝ ʇ,upıp ı  ˙ʎɐpoʇ ǝʞıq ǝɥʇ oʇ ƃuıɥʇ ʇou pıp ı
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #11660 on: August 21, 2012, 10:24:44 AM »
Got filters in the mail yesterday while i was at work. Today i gave them a test fit. Had to trimm them up a bit at the mouth of the flange but its not bad they are real small like i wanted. Now pilot jets and a set of headlight ears and it will be on the road again. Maybe a clutch adjustment. If anyone has any good threads on that it woulld help lol.
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
"Alley Cat"  93 sportster
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #11661 on: August 21, 2012, 10:28:37 AM »
« Last Edit: August 21, 2012, 10:33:29 AM by Gurp »
« Reply #11662 on: August 21, 2012, 10:40:42 AM »
for once someone posts with our AU and NZ brothers in mind  ;D
Offline MoMo
  • Ride like you're invisible
« Reply #11663 on: August 21, 2012, 12:27:47 PM »
Good one! ...Larry
Offline evo42
« Reply #11664 on: August 21, 2012, 04:00:17 PM »
Ordered bottom end gaskets and oil filters and o-rings.  Scraping gaskets tonight too...
« Reply #11665 on: August 21, 2012, 04:13:09 PM »
+1....ordered gaskets for the K2 project bike
Offline Tews19
  • I am no
« Reply #11666 on: August 21, 2012, 06:29:19 PM »
Briar brown K2? Are you taking the engine apart or building one from your mother load?
1970 Honda CB750 survivor.
maduncle
« Reply #11667 on: August 21, 2012, 06:59:15 PM »
Decided to invest in a nutsert/rivnut tool for the workshop, since I am busy working out mounting points on parts and how to secure them.
This should make adding nuts to brackets much easier than welding, I am going with a "6mm maximum" tool, anything over 6mm in a nutsert probably DOES need welding.
« Reply #11668 on: August 21, 2012, 07:00:15 PM »
Valley Green K2. Motor only has 23K miles, hoping it is good to go!
Need to get the wiring sorted first, no spark yet.  this weekend...
PS  got the shocks, thanks
Offline nccb
  • 1974 CB750 Four
« Reply #11669 on: August 21, 2012, 07:23:47 PM »
replaced the starter motor and gear, glad that's over ;D
Offline Jerry E.
« Reply #11670 on: August 21, 2012, 08:49:23 PM »
Got my custom oil tank fitted to the frame mounts, and cut off all un-needed frame tabs. Oil tank is looking very good-aluminum should polish up good.
"Why jump from perfectly good airplanes? Because the door opens."
« Reply #11671 on: August 21, 2012, 08:57:29 PM »
about a 30 kay ride running errands,still havent wound it past 6500 yet,its gaining torque the more i ride it at the moment,must be loosening up nicely?
« Reply #11672 on: August 21, 2012, 11:12:49 PM »
Where'd you buy it Cliff? That's one of the few tools I've never bought. Cheers, Terry. ;D
maduncle
« Reply #11673 on: August 22, 2012, 12:11:18 AM »
Your mate John (I pick it up Saturday) and you can borrow it off me whenever you want.
« Reply #11674 on: August 22, 2012, 12:16:37 AM »
Woohoo! What time are you picking it up so I'll know what time to come around to borrow it? Ha ha, just jokes, I've always admired them, just not sure what I'd use it on. ;D
