Author Topic: Patina Hyena - 550/650 674cc Hybrid Cafe Build  (Read 399461 times)
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: Patina Hyena - Dave's '78 CB550K Cafe Build Thread
« Reply #825 on: September 06, 2015, 07:02:39 AM »
http://bfy.tw/1ey4
As mentioned, marine grade might be a good choice (4th on the list in the link above):
http://www.cabelas.com/product/Marine-Grade-Wire-ndash-Gauge/700341.uts?productVariantId=1196763&srccode=cii_17588969&cpncode=39-76349772-2&WT.tsrc=CSE&WT.mc_id=GoogleProductAds&WT.z_mc_id1=00013183&rid=20
The finer the copper strands, the more flexible the wire. The more strands that are used increase the "effective" gauge of the wire and can actually reduce the overall diameter of the wire as the strand count (and price) increases.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline DaveBarbier
« Reply #826 on: September 06, 2015, 07:20:20 AM »
http://bfy.tw/1ey4
Haha, the old LMGTFY. I HAVE looked, but it's hard to know what people mean by flexible. I have 6 AWG marine grade wire that was advertised as super flexible. It's just not flexible enough :(
This is the kind of flexibility I need.
You can see it at the 40 second mark.
They sell them only as 2' lengths. I put an email into them to see if they sell longer length, though.
Thanks for the links, both of you. I'm checking them out now.
Offline DaveBarbier
« Reply #827 on: September 06, 2015, 03:45:41 PM »
Just want to give props to the double crimp tool. This thing is amazing. Works on tiny wire and big wire and also groups of tiny wire (picture of three small wires). Makes things so clean and it's quick to use.
In case anyone doesn't know where to get one: http://www.cycleterminal.com/crimp-tools.html
Offline Restoration Fan
  • My wife will never call me
« Reply #828 on: September 06, 2015, 07:46:25 PM »
Which model of the tool did you buy, Dave?
Offline DaveBarbier
« Reply #829 on: September 06, 2015, 08:08:44 PM »
Good question, I have no idea. It's the one in the link I added in my previous post. Which ever that model is, that's the one I have.
Only gripe: I wish the ratchet release had a lever that I could push so I could open the jaws without having to completely close the crimper. Do you have one?
« Reply #830 on: September 06, 2015, 09:16:11 PM »
Right on! Using them just once is usually enough to make you appreciate their value.  8)
That blue and yellow wires are just a practice crimp, right? If you wire the blue and yellow from the ignition like that it might be hard to start!  :o  ;)  ;D
The crimp tool from Vintage connections has a ratchet release. As for the one from cycleterminal, what is that little tab under the handle?
TAMTF...
Wilbur
Projects:
Offline DaveBarbier
« Reply #831 on: September 07, 2015, 04:49:42 AM »
;D Yes, that would make it hard to start. Good thing this is the ground for my neutral and oil pressure indicator and backlight for speedo!
Yeah, this has the same kind of release. But since there no external lever or button or something, if the handle is squeezed...like half way...you can't get your finger in there to press it. Unless I'm totally missing something?
Offline DaveBarbier
« Reply #832 on: September 07, 2015, 06:20:25 AM »
I thought we had a conversation about GROUND wire colors...  >:(
And, the BLU/RED and GRN/RED are the GROUND wires for the OIL and NEU light! On your gauges, you need to supply power to those circuits and use the stock BL/R and Gr/R wires as the ground side-
Oh, whoops, I misspoke. The wires in the picture are the ground for the high beam indicator, the signal indicator and back light. I've been looking at wires for hours on end so I got a little confused.
Offline DaveBarbier
« Reply #833 on: September 07, 2015, 11:38:11 AM »
Got an electronics question for the savvy out there. I have aftermarket gauges and my LED high beam indicator is too bright. Not sure why they made it that way, but maybe I'm just sensitive.
Anyway, I found that if I use about 30k ohms resistance then the light is perfectly bright for me. To achieve that, I used three 10k .5 watt resistors. In doing my rewire I want to keep the brightness down but I'd rather use one resistor instead. I have a 33k resistor that appears to be .25 watt. Is there an issue with that wattage? I can't imagine the LED for the gauge indicators use a lot of power but I don't want to burn this little thing up.
« Reply #834 on: September 07, 2015, 01:50:24 PM »
You would only see 4.363635 mW being used by the resistor if it were in the circuit alone. So, it would be safe to use the .25W resistor in series with the LED.
If you wanted it to be adjustable you could wire in a 33k ohm linear potentiometer. But, then you would need to make it watertight as water inside the pot would destroy it.
similar approach for bright days would be to have the LED switched on or off taking it out of the circuit during the day. If you hook it up and it is getting too hot to hold then it is likely drawing more current than expected and could need some special handling or a larger power rating.
Home Astronomers can use a simple resistor array with low wattage resistors to keep their optics fog free on humid damp nights by warming the mirrors and lenses.  They generally have multiple settings to vary the heat output.  Simple to make for those wanting to do so.
David
Offline DaveBarbier
« Reply #835 on: September 07, 2015, 02:27:34 PM »
David
Thanks for the reply, Dave. That is the only thing in that circuit but it's tapped into the headlight high beam circuit. Not sure if that matters or not. If you care to see the wiring diagram I'm using its back a few posts. You can see how it's wired up.
Cool thing with the astronomers condensation reducing. My friend has a nice telescope so I'll pass that info along.
Thanks again!
« Reply #836 on: September 07, 2015, 06:51:32 PM »
I told you to use solid GREEN for all your ground so you wouldn't get confused! Using BL and Ayala as grounds will be very confusing down the road...  ::)
Yeah, but blue and yellow together are GREEN.   :o ::) ;D
Offline DaveBarbier
« Reply #837 on: September 07, 2015, 07:37:10 PM »
But those are the wires coming out of the aftermarket speedo. What do I need to do, open the gauge and hard wire in correct colors?! I'm not that anal!
I'm using the exact colors that are in my diagram. All grounds are green! (Except the above mentioned...and ground battery cable...that's black.)
« Reply #838 on: September 07, 2015, 08:18:24 PM »
So I'm still having an issue with getting the right battery/starter cables. I have some really nice 6 AWG but it's too stiff to make the bends to the battery.
I do have some nice, super flexible 8 AWG wire, is that ok to run as the frame engine ground, battery to starter solenoid and solenoid to starter?
Or, do you guys have links to a good resource for super flexible 6 AWG wire by the foot?
I know where you can get silicone sheathed very high wire count and flexible wire, could you use multiple strands to essentially build an equivalent to a 8 AWG wire.
It will have the drawback of being thicker than equivalent because of the added insulation.
Just a thought if you wanted to go that route.
Essentially, a stranded wire is built this way. You would just need to build the equivalent with three strands of 12ga to exceed the circular cross section of an 8awg ga cable/wire. .  They could be stripped of insulation and built as a braided strand then shrinkwrapped. It would not be as flexible as just three strands crimped into a single terminal at each end.
« Last Edit: September 07, 2015, 08:38:26 PM by RAF122S »
« Reply #839 on: September 08, 2015, 12:05:33 AM »
 ;D
« Reply #840 on: September 08, 2015, 10:37:07 AM »
Forgot to tell you the source for the silicone wire is a good hobby shop catering to RC cars or aircraft.  Theu commonly stock at least a 14ga silicone sheathed wire snd often have a 12 ga as well.  It is at least a 49 strand or higher count strand construction.  It could be a 60, I have not counted it but it is super flexible with a good silicon insulation.  Negative about the silicone wire insulation is it can be abraded very easily by vibration and sharp edges, so you must be certain it is protected.  They carry red. And black and will often have blue.
David
Offline DaveBarbier
« Reply #841 on: September 08, 2015, 11:50:25 AM »
David
Thanks Dave, I was looking at that kind of wire during my researching. I have some wire coming in in the next couple days that should be perfect. We'll see. I've known that welding wire is good to use but in looking around I found that two brands are what people say is the best stuff in terms of chemical/abrasion resistance, flexibility and conductivity. They are Tough Flex and Tristar. I'm getting in some Tough Flex...fingers crossed.
« Reply #842 on: September 10, 2015, 03:36:39 PM »
Any progress on the 650 power plant, or is that on hold until Winter?
Offline DaveBarbier
« Reply #843 on: September 10, 2015, 05:05:22 PM »
On hold-ish. Need to get carbs from Godffery when he has the CR26s in stock again (the used ones I got didn't work out) so I'm getting new ones and I'm still trying to get a hold of Mike to talk about machining. Although funds are tight right now so that's good I haven't heard from him, haha.
But my goal is to buy the carbs, get all the machining done and start assembly of the motor before the new year. I want to drop the new motor in the frame mid winter.
Also in the process of building an additional shed on my property (actually a shipping container which I'll make into a shed by adding windows and such) which will give me more room for my work space.
How about you?
« Reply #844 on: September 10, 2015, 05:54:46 PM »
How about you?
I spoke to Mike today. My cam and rockers should ship directly from Megacycle soon. Head and cylinders are at the machinist. All other engine parts ready to go.
I am also looking into a shipping container for a shop. I spend too much on my storage space.
Offline DaveBarbier
« Reply #845 on: September 10, 2015, 06:56:54 PM »
Awesome sounds good, Don. I can't wait until I'm able to go ahead and get the machining done.
Offline DaveBarbier
« Reply #846 on: September 13, 2015, 07:08:01 PM »
Question on wire cross section (millimeter squared) vs AWG. My m-unit says not to use smaller than 10mm2 for the power. It comes with a wire that says 10mm2 on the insulation which is almost exactly the same size as some 8 AWG I have (but I've heard some people say it's 10 AWG). But if I measure the wire diameter I get about 5mm. What is the 10mm2 referring to? AND if you go use a mm2 to AWG converter online it says 10mm2 is about 7 AWG.
Please shed some light on this, I don't get it! Thanks!
« Reply #847 on: September 13, 2015, 10:18:54 PM »
Insulation thickness varies with the specs that the wires are rated at and the insulation type. The copper wireinside is made up of strands of smaller wire. They typically start with 7 strands, one wire in the center with six wires surrounding it. Flexible wire is going to have at least 49 strands with it going up from there. The wire size and space between wires plays a role in the actual coper density or cross sectional are. This can be measured in two axis to give mm2 (squared millimeters) or expressed as a decimal reading in inches squared.
American Wire Gauge (AWG) is used in the USA but most countries in other parts of the world go by mm2 measurement.
I am not sure how you really can measure it accurately.
Lots of commonly found wire strippers are designed for solid wire, this is why you end up cutting some strands of very high count stranded wire. Most of the time it is not going to matter much losing a few wires of a stranded wire of over 100 wires. We aren't dealing with things requiring high tolerances.
Go to Wikipedia and read up on the stranded wires and insulation type and things like that if it suits your curiosity.
I don't know how to tell you to measure a wire if it isn't marked. Like you said, you can get close using the wire strippers starting large and working down to see which one cuts through the insulation without cutting the strands. Otherwise, you need the specs on the wire from the maker.
David
Offline DaveBarbier
« Reply #848 on: September 14, 2015, 01:56:03 AM »
David
Oh ok, haha. I'm glad it's more complex than I though and I wasn't just measuring it wrong.
Thanks!
Offline DaveBarbier
« Reply #849 on: September 19, 2015, 09:14:14 AM »
Might be able to finish the wiring soon and go for a ride today! Coming together really nicely.
For fuse holders I'm using GM/Delphi fuse holders. They're awesome.
After talking with the guys over at a Revival Cycles (they answer questions really quickly about their products even if you don't buy from them) and they said that the wire that comes with the m-Unit is "absurdly large". They use 12 AWG for the power. I settled on 10 AWG because the fuse holders only go up to that size. And it's not easy to find (although I eventually did) inline fuse holders that take ATC/ATO fuses for 8 AWG (the size of the included power wire).
Got a cheap but nice ferrule crimper off Amazon because I wanted to make sure these things are secure and strong and that they last. Also, I wanted a more professional look.
Progress so far:
