Author Topic: Patina Hyena - 550/650 674cc Hybrid Cafe Build  (Read 384565 times)
Offline DaveBarbier
Re: Patina Hyena - Dave's '78 CB550K Cafe Build Thread
« Reply #775 on: August 20, 2015, 02:03:54 PM »
That's a nice looking exhaust. This will definitely be an option, thanks Cal.
« Reply #776 on: August 20, 2015, 02:14:51 PM »
Dave - you and Don should check out a Ripple Rock Racers (www.ripplerockracers.com) in Canada for an exhaust. Couple of other guys use them on their 650 and they look awfully nice and comparable to the MGPWerks unit. Plus, Canadian/US exchange rates!
Approx US$460 for the pipe with no muffler in bare stainless.  Not bad.  Thanks for the tip.
I believe that Ripple Rock makes the billet triple clamps for Dime City Cycles.
Offline DaveBarbier
« Reply #777 on: August 30, 2015, 06:30:21 PM »
Still waiting on parts for the rewire. In the meantime, I made up this wiring diagram for me to follow.
Offline DaveBarbier
« Reply #778 on: August 30, 2015, 07:22:22 PM »
Just noticed you're missing a line from AUX to tail light to run the power for it.
I'm going I use the option for the one wire taillight. One wire to run from "brake" to do both taillight illumination and brake light.
It would be awesome if the m-unit had a little micro USB and you could upload settings that you create yourself. For example, since there's an accelerometer it can know when you brake hard, then it could pulse all rear lights in a panic stop. Or maybe a quick horn tap would do a "beep-beep" like you're getting someone's attention. The possibilities are endle...I mean...slightly more.
Offline DaveBarbier
« Reply #779 on: August 31, 2015, 04:41:09 AM »
Those settings are adjusted through the setup menu options.  ;) nothing about a beep-beep though... That's what the MotoGP 4:1 is for  8)
Yup, there's a lot of cool options. Like I wasn't aware that I could've done a start/kill by holding the left blinker and headlight (or whatever it is) Could've saved some money by buying two 2 button m-switches instead of the 2 and 3 m-switch.
Offline DaveBarbier
« Reply #780 on: August 31, 2015, 05:25:43 AM »
true, but you can use the dedicated 3rd button as a KILL in a moments notice. Remembering the sequence and getting it right in an urgent situation, well, let's just say whats a few bucks for clarity?
Agreed. But I still want to get access to the m-unit to upload my own configurations. As I understand it if I use the alarm option and it goes off, it'll turn off either if I cycle the key or by draining the battery if I'm not around. Would be nice to have duration settings on that.
Offline DaveBarbier
« Reply #781 on: August 31, 2015, 08:38:02 AM »
Was welding and painting the tail section yesterday to hold the battery and my little disk lock. A grinder and paint make up for what the welder ain't...
Offline DaveBarbier
« Reply #782 on: August 31, 2015, 08:38:58 AM »
Also, just got my pistons back from coating, nice! I ended up going with Swain Tech and they came out really nice.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #783 on: August 31, 2015, 08:49:45 AM »
Almost too purdy to install!
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #784 on: August 31, 2015, 08:54:26 AM »
Very nice, Dave.  Which model Shorai are you using?
« Reply #785 on: August 31, 2015, 08:54:56 AM »
That is mighty slick!
« Reply #786 on: August 31, 2015, 09:59:41 AM »
All kinds of expensive candy going into the build.  Looks great!
Offline DaveBarbier
« Reply #787 on: August 31, 2015, 11:23:12 AM »
Thanks Don. I'm using the LFX14A2. Nice and small but still has enough CCA. And should still be fine for the 674 when that goes in.
Offline DaveBarbier
« Reply #788 on: August 31, 2015, 11:25:21 AM »
Almost, haha. But I'll have time to stare at them since they're not going to be going in until at least a few months from now.
Offline DaveBarbier
« Reply #789 on: August 31, 2015, 11:30:30 AM »
Actually not really that bad. $40 a piston. And considering they're the 'apparent' industry leader in this stuff (or at least recommended from MRieck) then that's not too bad in my book. I blame CAL for the push! But I'm easily swayed.
In high school:
Friend- "here, drink this beer."
Me- "nah, I probably shouldn't."
Friend- "you sure? Ok, that's no probl..."
Me- "ok, if you insist."
« Reply #790 on: August 31, 2015, 11:53:30 AM »
Thanks, Dave.  Yeah, I think 210 CCA should be enough -- its the same energy spec as the larger battery to fit the stock battery sleeve in a more compact case.  I'm on it!
Offline P.abrera
« Reply #791 on: August 31, 2015, 06:18:43 PM »
In high school:
Hanging with Cal and Don is cancer to the wallet. I made the wrong kinda friends here and developed expensive tastes
Parts are looking great
« Reply #792 on: August 31, 2015, 08:14:29 PM »
I blame Dave for pushing me to dive headlong into my 650 project engine for The Hot Mess.  I would have happily taken another year to do it, but NO, Dave had to cajole me.   ;)
Offline DaveBarbier
« Reply #793 on: September 01, 2015, 05:26:45 PM »
I accept full responsibility. These bikes will be like brothers from other mothers...or sisters from other misters, whichever you prefer.
« Reply #794 on: September 01, 2015, 07:24:45 PM »
I like all of those monikers.
Offline DaveBarbier
« Reply #795 on: September 02, 2015, 05:09:16 AM »
Haha, awesome. Stepdaughters works for me. Maybe a family reunion should take place somewhere in middle America.
Offline DaveBarbier
« Reply #796 on: September 02, 2015, 06:25:10 AM »
I wish I'd be ready by then. That would be a nice trip to break the newly rebuilt motor in, though.
« Reply #797 on: September 02, 2015, 07:38:17 AM »
I wish I could be ready or find myself at COTA. Maybe in April to see MotoGP and The Handbuilt Show.
Offline DaveBarbier
« Reply #798 on: September 03, 2015, 02:38:30 PM »
Finally got my m-Unit, and two m-Switches. They're really beautifully made. The m-unit is heavier than I thought it would be. It has a nice weight to it that makes it feel like a quality piece. I got my stuff from TruNetWholesale, cheapest place I found. They have an eBay presence but I went through them directly.
Here's their eBay store:
http://ebay.to/1UvHWHy
And email:
truenetwholesale@gmail.com
Offline Restoration Fan
  • My wife will never call me
« Reply #799 on: September 03, 2015, 03:32:44 PM »
Dave,
Do you have a website for TruNet Wholesale?
